Rear camera image
Terrymo
Terry
2023 JLURXR 3.6 ET
I have the rear camera image showing correctly on the screen but if I take a picture with the rear camera it’s reversed (image is mirror image flipped). Is this normal, is there a setting for pictures I’m missing, or am I just mistaken? Thanks
Wbino
NJ
AI Overview
If your rear camera photos are reversed, you may need to adjust the "Mirror Image" setting in your device's camera app, or for a backup camera, you may need to cut a white wire on the camera's cable. If your phone's selfie camera saves the image reversed, you may want to check your camera settings for a "Mirror Front Camera" option or a similar feature to save them normally.
For a Smartphone
  1. 1. Check the Camera App Settings:
    Open your camera app and look for a settings menu or an icon that might allow you to "Flip Image" or "Mirror Image".
  2. 2. Enable the Correct Setting:
    If there's a "Mirror Front Camera" or similar option, you may want to turn it off for selfies to save them normally, or turn it on for a rear camera if you desire that specific function.
Terrymo
Terrymo
Terry
2023 JLURXR 3.6 ET
AI Overview
For a Smartphone
Terrymo
Terrymo
Terry
2023 JLURXR 3.6 ET
Thanks, I know I can flip to the mirror image on my iPhone. I’m just curious about the Wolfbox rear camera image showing correctly on the display but if I take a photo with the Wolfbox rear camera it’s reversed for some reason. I’m hoping I’m just missing a Wolfbox setting. @wibornz any insight?
yokramer
Snark Incarnate
AI Overview
For a Smartphone
Yea you need to stop relying on ai cause its shit homie.
yokramer
Snark Incarnate
Even ChatGPT knows AI is shit
It really is insane how wrong it is most of the time and people just blindly follow what gets shit out.
yokramer
Snark Incarnate
But anyway back to Wolfbox hopefully answering your question.
Wbino
NJ
At least this lazy forum member tried to answer your question before the maker of the expensive toy you have has....🙃👍
PT's19Rubi
Paul
NC - Just across river from Uwharrie trails
2019 Rubicon 2D, 3.6, 8A
Retired Electrical Design Engineer
If you look in your rear view mirror, the view is reversed (mirrored - "Jeep" is backwards). A rear facing camera really should do the same, so that you see the same image that you see in the rear view. And, like others have said, changing that image should be in the camera's settings. My guess, and it's just a guess, is that you have a setting for "mirror" for video, and another setting for still shots, and the two are set opposite to each other.
Terrymo
Terrymo
Terry
2023 JLURXR 3.6 ET
That makes sense. Thanks. I guess I’ll be forced to actually read the instructions.
Wbino
NJ
Trying to make my quota
Terrymo
Terrymo
Terry
2023 JLURXR 3.6 ET
That’s a great video. I’m sure there’s something obvious I’m missing since I’m tech challenged. I’m going to have to dig a little deeper to make sure I’m not just having another senior moment.
yokramer
Snark Incarnate
