Re-gear BEFORE bigger tires?
Triple Zero
Terry
Chicago
2022 Willy's
I've got a '22 JLU Willys 6sp manual. Looking to go with about 2" lift and 35" tires.
Considering a re-gear to 4.56, pretty much all on-road/highway driving. What happens if I do the gear change before the new wheels and tires?
Bonus question: Is there any benefit or problem with that same setup on 4.10 instead of 4.56?
Thanks.
2nd 392
Ca
Tires first will give you a better indication of what gearing to get.
Triple Zero
Triple Zero
Terry
Chicago
2022 Willy's
What kind of issues will I notice getting the tires first with the manual trans? Like, slower acceleration? Bad gas mileage?
Rubi6mt
Nj
2021 JLUR 6mt
I have a JLUR 6-speed. Currently running a 2.5inch lift and small 35's (KO2's 315/70/17). With the stock 4.10 gears (vs your 3.45's) its just about passable in 2hi daily driving. I'm basically 1 gear lower, ie instead of 4th i'm in 3rd etc. Offroading it works well (but i have a 4:1 transfer case).
With that said, I'm scheduled to have 4.88's installed next month along with the Centerforce II clutch.
2nd 392
Ca
How sluggish acceleration, how it holds 6th gear, tire weight will also have an effect. Mileage vs performance, I choose performance. Edit, 35’s vary from ~ 52lbs to ~ 80lbs
Some Random Guy
Washington
Comptroller
Ask your installer about warranty of their work. Mine only warrantied their work with stock sized tires. Probably should have been a sign of the problems I’d have.
kah.mun.rah
Merenkahre Jr.
Duat
There are a lot of factors that will come into play to determine which ratio will be best for you so I agree with @2nd 392 and would get the tires 1st and then see how much performance you lost to help decide on how much you need to re-gain. Also keep in mind any heavy mods that you might add in the future and if you think that you will ever go to 37s.
Tncdrew
Tom
East Tennessee
2022 JL Willys, 3.6L - 8spd
I've got a '22 JL Willys 3.6 8-spd. No lifts planned, and when I get tired of these noisy Firestones, I'll probably go no bigger than 285's (33"). I'm looking to re-gear to 4.10 with all that. I think it'll be a great mild trail runner, and better on road as well.
LOBBS
Kyle
Independence, MO
JLR
Quality Manager in Automotive Aftermarket
Jeep offers the 4.88s as a factory option now for the stick. Manuals tend to need a little more gearing than automatics. With 35s, I'd go no lower than 4.56s with your setup but I'd strongly consider 4.88s. I went to 35s on my JLR and noticed a hit to my acceleration, gas mileage and just overall driveability. I've got 4.56s on order but I'm an automatic and honestly can't wait for the rears to come off backorder so I can get them installed (the front gears and install kits I've had for probably a couple of months now).
Triple Zero
Triple Zero
Terry
Chicago
2022 Willy's
That was also something I was considering, just doing 4.10 and going with Rubicon sizes tires at some point.
Tank the Jeep
Greg
Charlotte NC
2020 JL Rubicon Diesel
I had a JK 3.6, manual and 4.56 gears. With 35s the 4.56 was perfect. Plenty of torque. Sixth gear was actually useful. I think you will have a great set up.
Tncdrew
Tom
East Tennessee
Yep, that's my plan! I'm a gearhead at heart and love reading about all the gears, tires, and lift kits, but all my rock crawling days are in the past, and now just looking for a decent mild trail ride. ?
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
I had a 3.6 JK with 35s. Once I moved to Denver i wish I would have gotten 4.88s instead of 4.56.
Rodeoflyer
Bert
Conifer, Colorado
Yes at high altitude (+4000 ft) you want to regear prior. Hell, even at sea level I've had richmond 4.56 in a street car with 20'' wheels on zr30's.
