Raingler Barrier Net Review
ChuckQue
Charles
www.stayreadyoutdoors.com
2022 JLURD
Owner of Stay Ready Outdoors
Today I put in the Raingler full barrier net, which I had a variation of in my XJ and really liked. The JL version is just as well built with tight, neat reinforced stitching. You can order it in many various configurations and color options. I opted for black with red stitching to match the Rubicon interior.
Install is super easy. There are two small brackets, one of each which install between the hard top and tub using the forward most hard top bolt on each side. Then you just feed the straps around the sport bars, the two brackets and the two cargo hook points on the floor.
The ONLY complaint I have is they clearly designed it using a non subwoofer or trail rail equipped JL. Normally the net fits very snug and tight all around, however, because I have the trail rail the hooks on the floor must be closer together making for a loose fit on the bottom. It’ll still perform it’s intended function which for me is to mitigate the risk of gear in the back from becoming a projectile in a crash. Now, if the seats were folded down I could see it being an issue maybe, BUT I can’t see a scenario where I’d have the seats folded down and the net still up. Once all my gear I regularly carry is loaded into the back my OCD won’t care as it won’t be visible. If I were ordering again knowing what I know now, I’d opt for the upper half coverage version for my configuration.
I’m still happy with it and would highly recommend purchasing from Raingler.
Jeep Wrangler JL Raingler Barrier Net Review 74741A61-F90F-4C6F-8162-CB8BAE1004CA
ChuckQue
ChuckQue
Charles
2022 JLURD
I emailed Raingler last night about the bottom mounting points and someone got back to me almost immediately. I was surprised because it was fairly late, talk about customer service! They asked me to see if the straps would reach the passenger seatbelt mounts and to report back if that worked. I’ll give that a try in a bit here.
ChuckQue
ChuckQue
Charles
2022 JLURD
Success! I used the car seat attachment points. I didn’t like how the strap interferes with the seat belts when using the seat belt mount, though I’m sure it would be fine.
Jeep Wrangler JL Raingler Barrier Net Review E93C5761-E39E-4F08-8B79-CE9D58251D41
ChuckQue
ChuckQue
Charles
2022 JLURD
Raingler wasn’t satisfied with the tautness of the lower portion and is sending me out a set of brackets and extensions that will mount to the lower seatbelt brackets. I love good customer service.
