Radio ?
SIGP2101
Canada
JL 2021 Rubicon 2.0T
Can I listen radio while my JL is not running?
Suffolklou
Lou
Richland Wa
2020 JLUR
you have to be in accessory mode. push the start button without mashing the brake.
If you want the radio only, and worry about draining the battery, maybe a portable radio?
SIGP2101
Canada
Thanks for the response but that makes dash lights, shifter lighs and some other cabin lights to come on which is additional drain on the battery.
Suffolklou
Lou
Richland Wa
2020 JLUR
Thats how it works, not sure what else you could do with the factory radio.
JeepU4IA
Rod
Los Angeles
2014 Dodge Charger R/T, 2018 Jeep Wrangler JLU
The drain on the battery from those other items is relatively small compared to the radio and its amplifier. My audio source is usually my phone so to avoid draining the Jeep's battery, I use a portable bluetooth speaker when the engine is not running.
jaymz
Jay
Inland Empire
2018 Rubicon Unlimited
The dimmer switch will turn most, if not all of those lights off.
Reinen
Utah
2021 Jeep Wrangler JL Rubicon
Turning the dimmer switch all the way down into the bottom "click" is what Jeep calls "Party Mode" (a silly name) which is intended for doing what you're trying to do. That will be as good as it gets.
