Radio apps
Army15Q
Erik
Wyoming
2024 Jeep wrangler Willy’s 4xe
So I have. A 2024 and on the radio head I do not have the hybrid pages, trail maps, and on off road pages with all the gauges the oil temp and oil pressure just have two dashes… they don’t work. Anyone have same issues? Dealer does not know how to fix…
@JeepCares
pfletcher229648
Patrick
Orlando
2022 JLUR XR w/SOT, 2024 JLUR X w/SOT(On Order)
CIO
I’ve had different issues but not those. My suggestion if you haven’t already done it is to make sure all your fuses are seated properly. Take the cover off of the fuses and press each one down firmly. Then perform a factory reset on the radio head unit. It takes about twenty minutes to do the factory reset.
Army15Q
Erik
Wyoming
WHATS the right way to do a reset on these new radios?
AndrewS85
Andrew
Maryland
21 Rubicon
Following as I have a 2021 rubicon with the same “issue”.
rohdawg
Long Island, New York
Merchant Marine
In your settings go to the vehicle app
Settings -> reset-> factory reset
Let it reboot completely and leave it alone for 30 minutes or so.
I shut the Jeep off and walked away because it takes a while for everything to reload. When you execute the factory reset it will even warn you about certain options not being immediately available afterwards.
Come back later, start it up and see if that didn’t solve your problems.
rohdawg
Merchant Marine
It’s different for a ‘21 vs a ‘24.
With the Jeep on, pull fuse 97 in your fuse box (PDC) and than put it back, shut it off and walk away for a while.
Your radio will reboot and also take a half hour, if not more, to reload/relearn your Jeep.
AndrewS85
Andrew
Maryland
21 Rubicon
thank you I’ll do that today!
tomk62
Tom
South Carolina
2024 JLU Sahara Anvil, 2019 Cherokee
You won't get the trail maps (Trails off road) unless you have the nav option.
If you do have the nav option, for some as yet undisclosed reason trails off road won't automatically deploy to your radio and you need to get @JeepCares involved to make that happen. It's still a mystery why it's not rolled out to all eligible.
rohdawg
Merchant Marine
Not accurate anymore. I never got them involved, did the factory reset on my own and the TOR app loaded just fine.
tomk62
Tom
South Carolina
Well that's good to hear! (but shouldn't need a reset ...)
rohdawg
Merchant Marine
I’m 100% positive the factory reset pushed an update to the Uconnect when it came back online. This was three days after taking delivery.
The thing is basically a computer and just like turning on a computer/ipad/new phone for the first time it’s a good idea to check for updates if the device doesn’t do it on its own.
AndrewS85
Andrew
Maryland
21 Rubicon
still don’t have the off road app. Could it just take longer to update?
AndrewS85
Andrew
Maryland
21 Rubicon
Quick note, I have the 7” screen in case that makes a difference.
rohdawg
Merchant Marine
The offroad app is only available on the 8.4” uConnect on the ‘18-‘23 model years.
BigMaCro
Moved to Iowa from Alaska
www.youtube.com
2021 JLU 4xe Rubicon
Carhauler
On my old '21 uconnect, after a dealer service where they disconnected the battery, I noticed my color/theme settings were different, and that the apps were missing. I freaked out, but read this forum and found that this often happens after power reset. I calmed down, drove home, and the next day all was restored and well with the world.
