Question regarding final impedance to 4 channel amp
XJCJ
TN
19 Sport 6-Speed
For some reason I haven't seen this mentioned at all here unless Im missing a thread, but with the non-alpine system, if you have 4 ohm speakers in the dash and knees, that would be a final impedance of ~2ohms to the amp, yes? I have read that the front channels are wired in parallel so that would make it so. Trying to set gains on my amp with multimeter and just want to make sure I have the numbers right to calculate the voltage
CO2Wrangler
21 JLURD
In theory, that's correct. 4 and 4 in parallel would be 2ohms to the amp. I have the Alpine so can't confirm your particular case.
It's tough to find a 2ohm stable 4 channel amp but hopefully you've done your homework.
XJCJ
TN
19 Sport 6-Speed
Im running the kicker 660.5, have been for a few months. Im just finally getting around to properly setting the gain, previously I just did the ear method but i had some spare time today
Jebiruph
Jerry
Iowa
2018 JLU, 2020 JT, 2024 WL
I think it's a 4 in parallel with an 8, so 2.67 ohms.
XJCJ
TN
19 Sport 6-Speed
I have replaced all stock speakers with 4ohm kickers. Also wouldn’t a 4 and an 8 be 6ohms?
CO2Wrangler
21 JLURD
Nope. Ohms law is weird. It's the product of the impedances / sum of the impedances.
In your 8 and 4 scenario: 32/12 = 2.67
In your 4 and 4 scenario: 16/8 = 2
** This simplified math only works for 2 speakers. The real equation is 1/x = 1/Ra + 1/Rb + 1/Rc.... **
Jebiruph
Jerry
Iowa
That's seems easier than calculating the inverse of the sum of the inverses like I was taught.
1/(1/n1 +1/n2 +1/n...)
Jebiruph
Jerry
Iowa
Keep in mind that any parallel resistance will always be less than the lowest resistance involved. A 4 and 8 in parallel has to be less than 4 ohms.
