4 Channel amp crossovers?
Rssazn
Virginia
Wrangler JLU, Grand Cherokee L, BMW M5
Just recently installed kicker 4 channel amp and I've upgraded all speakers. Should I turn on the crossover or keep them off?
Rssazn
Virginia
Not enough information to answer adequately.
okay... I'm new to car audio. what would be the benefit of enabling the crossovers on my 4 channel amp that are only powering my speakers, not subs. Head unit is aftermarket Stinger 10"
Vanburi
North Texas
2019 'Mojito' JLR
Benefit is sending frequencies to speakers that don't support them will muddy the sound.
Granted, I am no expert but would suggest you hit up a car audio site for better help in tuning your setup unless you are satisfied simply adding the additional power punch.
tomk62
Tom
South Carolina
2024 JLU Sahara Anvil, 2019 Cherokee
Do you have subs? If yes, turn crossover on as Vanburi said, otherwise have crossover off so your speakers get some bass.
Rssazn
Virginia
I have a separate mono amp that feeds the sub. running dual amp with the 4 channel to all the speakers.
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
The mono amp should have your sub low pass'd. You can high pass the rest around the same frequency.
