question for those with knowledge about outback adventure tailgate table
nositting
PA
19 JLUS
can this be opened with one hand? website says yes but looks like there’s two latches. i’m guessing if you hand one hand full, you have to undo one latch and then the other with one hand? thanks for any info!
dpike
New Jersey
'20 JLUR 3.6
I have one. Yes, both pin locks need to be pulled out, together or each separately. Maybe remove a pin or blank the hole over it you only want one lock. It will probably rattle a bit but it should still hold the table up.
tjeeper
Patrick
Nevada
'24 392
You can with one hand, but it is awkward. Pull one pin, twist it a bit so it doesn't go back in, then the other one.
THAW
Foster
23 JL4DrRubicon
tjeeper
Patrick
Nevada
'24 392
This was the original one, which I bought in '18. I just installed the new one with latches in my '24.. Much easier to open, and doesn't rattle.
wheelsfeels
Rock Sponsor (Level 1)
Anton
Houston, TX
wheelsfeels.com
Jeep Wrangler Sport JLU 2020
