Question about the mopar floor mat
Sjung5
Sung
Maryland
sUbaru BRz
Jeep Wrangler JL Question about the mopar floor mat E9D93CBA-61F0-4981-864D-4978265BD52D
hello
Anybody on here know where I can get an extra cover for this drain hole?
Thanks
falcon241073
Trey
Byhalia, MS
2021 JLUR
Same cover that's in the floor. Northridge4x4 and quadratec sell them. Probably on Amazon too
TMD78
Troy
PGH
Back again with JL#3, 2 door Willys
Definitely lift up the carpet underneath that hole and use that one that should already be there. The piece of carpet is already perforated so you can just pull it out with a slight tug, then pull the plug and use it on the mat as intended, it works great! Spill something on the mat, just pull the plug and out it goes! Sloppy snowy shoes? Pull the plug and out it goes lol. I’ve used mine more than I expected.
Mikester86
Michigan wishing I was on a trail...
2022 JLR
The concern is the lack of a water tight seal and water intrusion from underneath should one traverse deep water. I left the drain plug in the floor board.
I don’t need water coming up from below all over the carpets and beneath the rubber mats because the bad seal on the floor mat drain tube. Something to consider.
Sjung5
Sung
Maryland
sUbaru BRz
Wow i did not know there was a cover under the mat! Thanks all!
