Bruceter
- Bruce
- Sep 27, 2020
- British Columbia
- 2020 JLU Wrangler Rubicon,
As many of you reading this I have also spent endless hours reading all the posts on the different side steps and rock sliders. A couple of conclusions I came to was if one is going hard core wheeling then the frame mount would probably be the choice. The other being why would anybody go with a combination frame and body (pinch seam) mounting. The engineers put those rubber cab mounts in for a reason and why anybody would try and tie the frame and body without any flexing is beyond me.
On my previous JL Rubicon Recon it came stock with the Mopar Performance sliders which I did like the function and looks of them. They were just wide enough to protect the sides of the Jeep as well as the rear door hinges and fronts of the rear fenders.The new Rubicon had the standard sliders which all of these are body pinch seam mounted.
The Jeep for us is a transition vehicle from years of atving but we still like to get off the beaten path. So it will pulled behind the motorhome as a run around vehicle and scenic off roading. So I saw no need for our use to stick with a true frame mounted sliders.
I had looked at the Mopar Performance Rock rails and here in Canada they were close to $1600! Ouch! So looked for another alternative that was close to the same width as the Mopar rails and ended up with the Quadratec Brute Strength side steps. These came in at almost haft the cost of the Mopar sliders. I purchased from Just Jeeps here in Canada. Delivery was about three weeks time.
They came very well packaged and interesting enough they actually made in Russia! Having a good look over of them I was quite impressed with them, thereās absolutely no shipping damage and finished with nice clean welds and powder coat finish
I had previously removed the stock Rubicon sliders and sprayed the pinch seam with black truck bed coating.
I installed the new Quadratec side steps in about an hours time, again very impressed with the fit to the Jeep, there was nothing to alter or reaming out holes to get them to fit. If one has short fat fingers you may have a bit of a job getting the nuts started on the pinch seam brackets. They also fit up nicely against the previously installed Weathertec front mud guards. Over Iād give these steps a 9/10 for my use. The only reason I didnāt give them a 10 is they are straight and the Jeep tub has a bit of a curve to it so the gap to the body is slightly larger at the back compared to the gap at the front.
Hopefully this review will help some folks out.
