anotheraznguy
- Jul 30, 2018
- Tracy California
- Mojito JLUR
- Vehicle Showcase
- 1
I recently installed the PSC steering and everything is working pretty good on the street. I ran some tests to check for clearances and ran into an issue where the pitman arm would hit the stock rubicon sway front sway bar when the front driver was at full droop and turned hard left.
My question, is how can i resolve this issue? I am not too familiar with how the stock clock spring works on the JL. Is it possible to just shorten the drag link till the steering wheel makes a complete 360 or will that cause issues with all the electronics? If that is an issue would i then just need to unbolt it from the box and rotate the steering wheel a complete 360 degrees? I cant move the pitman arm on the steering box since it is keyed in one way.
The other option i had which seems like a pain is to just keep shortening the drag link until the pitman arm no longer hits and then remove the steering wheel and recenter it. This is assuming that the steering wheel isnt keyed to anything and would allow me to install it on a different angle.
I was hoping not to have to run manual disconnects on the end links or going to an antirock. Thanks
