"Performance Limited" Error code
Dood
NOVA
2022 JLUR
I’ve been getting the same message only during deceleration and or hard braking during highway driving. It got so bad the other during a 10 mile drive that I dropped the Jeep off at the dealership, 2 days later and still no resolution or path forward but definitely agree it is a bug somewhere in the code.
hiimmike
2022 Jeep Wrangler JLUR
Network Engineer
Interesting! I think I have some further information to give to FCA people. It does seem to only happen, as far as I can recall, during deceleration.
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
Other than the dash message, have any of you seen an actual change in driveability?
hiimmike
Network Engineer
I noticed what I believe to be a problem in CO. I was on I70 at the Eisenhower tunnel heading back East from Moab and it was metered. The light turned green for me, I pressed the accelerator and the Jeep didn’t go anywhere for about 5-8 seconds. Long enough for me to look down and see the vehicle was running and the RPMs were not increasing. Maybe altitude but it seemed all the other vehicles were were able to go.
jeepingib
Dusty
College Station, TX
18' JLUR Punk'n
BBQ prophet
Reading through this and I have developed a theory, but it would need someone to datalog to see if it's correct. It seems that this is happening when descending, decelerating, or braking. Which makes me think that there is something from that kinetic energy transfer that is causing a loss of fuel pressure. I don't know how much of the fuel system is different between the 3.6 and the 2.0. I assume that the tank, pick up, pump, filter assembly is the same and at least some of the fuel lines along the frame. So this seems like something that would be located on the engine itself. Perhaps the fuel rail.
Dood
NOVA
2022 JLUR
One of the times when the pop up happened I did feel a bit of sluggishness and it kind of felt like there was some kind of timing retardation happening.
hiimmike
Network Engineer
*** UPDATE 3/11/22-
Talked with Ron, my case manager, and I requested we get an engineer or engineering team involved. He said there is a team called STAR that is their engineering team. He is waiting for the dealer to call him back. I asked if I could bring the vehicle in soon and they could start troubleshooting. Now again I'm waiting. Ron will call me back with an update by next Friday.
hiimmike
Network Engineer
So you saw this under acceleration? I don't think I've seen the message under acceleration. Next time I see it, I'm going to floor it.
hiimmike
Network Engineer
I told my Jeep case manager, Ron, this is what I seem to be observing from my experience and others on the forums. The whole deceleration thing when we see the message. However, someone did mention they saw the message while under acceleration, like one up from this post here. I'm going to drive around and see if I can reproduce the issue by braking and then floor it and see if I notice any acceleration issues.
Why am I doing Jeeps job for them????? @JeepCares You should give me a free Mopar lift or something. :D
Initial-Jeep
Julian
. Greensboro, North Carolina
'22 392XR Tuscadero, PT Cruiser Dream Cruisers 2&4
Data Engineer, Retired Air Force
I'm curious if there's a difference between decelerating from under boost vs. not. I wouldn't be surprised if it occurred after a transition from moderate-to-high boost to no boost/vacuum.
Jebiruph
Jerry
Iowa
2018 JLU, 2020 JT, 2024 WL
The fuel system on direct injection engines like the 2.0 operates at a much higher pressure than port injection, so none of the pressurized fuel system would match the 3.6.
jeepingib
Dusty
College Station, TX
18' JLUR Punk'n
BBQ prophet
I had forgotten that the 2.0 is direct injection. I will be honest, I know very little about this engine. I am assuming that it is common rail injection like a Diesel. If so I would wonder about the high pressure pump. Maybe it is cavitating under the negative g forces of braking, etc?
jdecosta
Joey
Gainesville, GA
2022 Jeep Unlimited Rubicon
Thinking about this, I think it only seems to happen to me under deceleration. Anyone else seen it happen under acceleration?
Same here, I was decelerating going into a right hand turn.
jdecosta
Joey
Gainesville, GA
I was thinking that the fuel pickup location or baffle design in the tank have changed and cause it to momentary lose fuel.
