Oracle Heated New Sensor - where to mount?
lalalofsky
Ben
Lawrence, Kansas
2020 JLU Sport
Where am I supposed to mount the new exteneral temp sensor for the lights at? I have no clue where a good place is where they won’t get dirty.
ORACLElights
Peak Sponsor (Level 2)
Metairie, LA
www.oraclelights.com
2019 Jeep Wrangler JL
Automotive LED Manufacturing
The updated kits now have an external temperature sensor. The most ideal spot to mount this would be somewhere on the grill but you may not want this to be visible. Ideally, this should be mounted in a spot where there is the least amount of engine heat.
WVDieselNut
Richard
Charleston, WV
Ram 2500, Wrangler JLU
I just installed mine waiting for Oracle to respond with the answer. I mounted my sensors at the bottom corner of the lights on the body tap behind the grill.
Jeep Wrangler JL Oracle Heated New Sensor - where to mount? 20230621_142610
ORACLElights
Metairie, LA
Hi Richard, The most ideal spot to mount this would be somewhere on the grill but I understand you might not want this to be visible. Ideally, this should be mounted in a spot where there is the least amount of engine heat. This location looks like it is likely fine though but might be exposed to a little more heat than on the grill itself.
