OMEJLPR10, rear spring spacer install
Capt Milks
MJ
Virginia
2024 Rubicon 2 door
Hello, has anybody installed the OME, OMEJLPR10, rear spring spacer? Just curious if it goes on the top or the bottom. (2024 Wrangler JL Rubicon 2 door) No instructions on the OME website.
The same is true for the metalcloak spacers. I have seen them on the top and on the bottom, Rear springs
jadmt
jeff
montana
Will they even fit on the bottom?
ironduke2
Ted
Utah
2-door Rubi 2.0
Pretty sure it goes between the existing top spring isolator and the spring... Disco brake line bracket (e-locker connector if Rubi), lower sway end-link, lower shock mount bolt... May wanna jack opposite side of axle... Spring will come out NP
