Granni44
- Gregg
- Aug 31, 2018
- Bluffton, South Carolina
- 2024 Willy’s X
Hello All,
I had a bad drivers side caliper. Piston wasn't functioning. So replaced both front calipers (Pads and rotors also). Went to do a vacuum assisted bleed. Both rear brakes bled normal. Bled the passenger front went ok. Took awhile as there seem to be quite a bit of air. Finished that and started on the driver side. Hooked my set up, cracked the bleeder. Nothin…. Hmmmm, i take off the line at the caliper. Nothing. Not knowingthe cause i slammed my head into a brick wall (read as, I bled the other three again. Back to the drivers, no fluid still.
Full disclosure the vehicle was driven a bit when the original caliper was acting up.
That said, any thoughts on what I may be able to do to solve this? I’ve read of a possible issue with the line? I am a garage mechanic.
Also no leaks, and with the motiv setup, the air was holding steady in the tank.
I am also wondering if the caliper going bad was a result of no fluid getting there?
Gregg
Gregg
