New electrical gremlin
Kingkat900
Ryan
Washington
2006 tj
So I just finished my triangulated rear 4 link. Now when I started the jeep to move it my gas gauge reads low witch its almost full. I also have the motobuilt fuel cell witch I installed a few months ago and has been fine.
Second is a service axle locker on dash. I have ud 60s with e lockers that have never gave me any trouble. I am lost on what the issue could be.
Kingkat900
Kingkat900
Ryan
Washington
2006 tj
So I checked the f40 fuse and have power there for the lockers but no powe at the plug on the axles. Anybody have any ideas or had a similar problem????
Beachcomber72
2022 JLU High Tide
Wouldn't that cause the fuse to blow?
Generally but Not necessarily. But bad ground can lead to improper voltage reading which is what I first thought of based on the low gas gas gauge reading. I definitely could be way off base though. I’d just unplug and reconnect any taps or pigtails and make sure every pin and connections are seated properly.
2019 JLUR
Anoka, MN
2019 JLUR
When you did the lift install did you lower the axle enough to maybe pull to hard on these harnesses? Check both and make sure they were not tweaked.
Kingkat900
Kingkat900
Ryan
Washington
2006 tj
No one of the first thing I did was disconnect the locker plug.
JLeco2022
Anaheim, CA
2022 Wrangler 3.0 V6 Eco Diesel
i would ring out all the wires to ground with a meter, my money is on a hardness
mwilk012
2018 Ocean Blue JLU Rubicon
Service
No power at the axle measured exactly how, on which pin from where to where? Do you have 10’+ of test leads?
There aren’t any ground wires to the locker harness. It’s direct connection to the drivetrain control module for every wire except the fused battery power.
Kingkat900
Kingkat900
Ryan
Washington
2006 tj
Problem solved!!!! Found a wire on passenger side that had been rubbing on metal and wore through the sheathing and grounded out. Thanks for the help.
OldGuyNewJeep
Don
CT
Any chance you can post a picture or explain where the wire lives?
