New bumpers
Wabujitsu
Sarasota, FL
2021 JLUR, 2020 JLU Sahara
Retired US Army
Wabujitsu
Sarasota, FL
Retired US Army
@Stuckinthesand CJ, if you relocate the solenoid box onto your bull bar, I opened the box (four bolts on the bottom), drilled through the bottom of the box into the bull bar, then used two larger diameter sheet metal screws to attach it, and then reassembled the box. It’s on there solid, and has already pushed through branches with no issues. I will probably take it apart this winter to see if there is any corrosion in the holes I drilled into the bull bar. If there is, I will hit it with some Rustolium paint, then seal around the screws with either silicone caulk and/or rubber washers.
Stuckinthesand
CJ
NJ
2019 Wrangler Sport S
Thanks Jeff. Looks like I may have a weekend project now. I’ve been thinking about it and this just pushed me to do it.
Wabujitsu
Sarasota, FL
Retired US Army
CJ, feel free to contact me if you have any questions, brother! I will PM my number to you.
Whiskey 13
Northwest Florida
2020 JLUR White Rubicon, Warn 10000 Lb. Winch Syn. Rope, 35X12.5 KO2
LOD makes a Signature Series and a Destroyer Series in full, mid and stubby. I put the mid width Signature series on my 2020 JLUR. I put a Smittybilt 12000 lb. winch on it as well. I had LED fogs in the factory plastic bumper and after removing the wiring harness from the plastic bumper (PITA) the fogs bolted right into the LOD bumper. Great strength and love the way it looks and I can flat tow the jeep (which was my intent) because of the bumper ratings.
Oldbear
Dwayne
Bowling Green, Ky
16 Ram 1500 Ecodiesel; 20 JL Sport S 2 door
I am looking hard at the Rock Hard Patriot Full width aluminum with a Smittybilt 9500 winch and synthetic rope. That combo should be less than 100lbs over the stock plastic. Anyone tried these bumpers?
Abend
Jeremy
Erlanger, KY
2019 Hellayella JLUR, 1948 CJ-2A, 2018 Sting Gray JLU Sport (the wife's)
I have the mid-width version of that bumper and I absolutely love it. It was actually a few pounds lighter than the stock plastic bumper I removed (especially when you include the giant plastic air dam and the steel plate underneath that you're pulling out). I think the full width is only 4 lbs heavier than mine, so you really are only adding the weight of the winch to the front.
Jeep Wrangler JL New bumpers IMG_7143
Kenbike
Ken
NE Ohio
2020 JL Rubicon
Have the RockHard 3/4 width Alum bumper with a Warn 10,000 lbs synthetic rope.
It is a great setup. The bumper itself weighs very little but the winch does add some weight. Good looking bumper!
Oldbear
Dwayne
Bowling Green, Ky
Thanks guys! At this point i think the Rock Hard aluminum is the winner for me.
