Need one backyard mechanic
ScotM
Scot
Southern California
2022 Jeep Willy's JL 2 Door
I thought I had my brakes all figured out after I mixed up the rear caliper brackets, but I still have doubts. I need one brave soul with Hd brakes to pull out their driver side rear lower caliper slider pin and post a picture for me. This can be done without removing the wheel, just the one bolt , move the caliper out of the way and slide out the pin. This would remove all doubt for me. The bolt just needs a bit of blue loctite and 27 ft-lbs to go back on. I know it’s a big ask, but it would really help me out.
Jeep Wrangler JL Need one backyard mechanic IMG_5092
jadmt
jeff
montana
ScotM
ScotM
Scot
Southern California
won't one of these images help? what exactly are you wondering about?
jeep jl front brake caliper pin
I need to see the slider pin that is located on the bottom of the caliper. The top and bottom are different. One has a boot on the end , the other does not. As pictured here. Which is top and which is bottom.
Jeep Wrangler JL Need one backyard mechanic IMG_5076
ScotM
ScotM
Scot
Southern California
jadmt
jeff
montana
I believe the bottom is the lock pin....so boot.
ScotM
ScotM
Scot
Southern California
That’s the best I could figure out from all my searches, I was just hoping for a visual confirmation. I do appreciate your responses, and it’s good to know that we both are thinking the boot on the bottom, if that is correct, I don’t have to redo my rear brakes.
ScotM
ScotM
Scot
Southern California
Terrymo
Terry
2023 JLURXR 3.6 ET
Disclaimer: Im not a mechanic. Don’t listen to me. Here is what I’ve been taught by someone who was not a mechanic whom you should probably also ignore. Hopefully someone better informed will confirm or refute this info.
ScotM
ScotM
Scot
Southern California
I saw that video, and it made sense, but it indicated that the pin with the bushing goes on the trailing edge, which on the rear of the jeep would be the top of the caliper not the bottom. So that’s why was confused.
Terrymo
Terry
2023 JLURXR 3.6 ET
Ok If the video is wrong or confusing I’ll delete the post
ScotM
ScotM
Scot
Southern California
So I got a hold of a new driver side caliper bracket, and in fact the booted pin is on the bottom. No more videos, no more drawings, just an actual part. Lucky for me, I put the brackets back on correctly. A good Saturday is in my future.
Jeep Wrangler JL Need one backyard mechanic IMG_5097
