My thick skull 37 vs 35
stretch-bsn
Northern VA
2018 JLU
Okay so I’m trying to wrap my brain around this…
Dana 44
3.73 gears
Steel C’s
Lift 2.5”
Current weight of my 35’s is 72lbs per tire
Weight of a light set of 37’s is 68lbs per tire
I sort of understand rotational mass but is it that big of a deal since the tire is actually lighter?
Saying that I’ve seen people wheel with 3.45 gears and Dana 30/35’s and 37’s but I know that doesn’t mean it’s good for any type of longevity.
Everything I’ve read says 4.88’s or 5.13’s for 37’s so I understand that’s the reasonable/smart thing to do.
Just wanted to understand better and see what some real world wheelers think.
Odds are I’ll probably go 35’s again but I’d love to throw a set of 37’s on there.
Mifsuud
Phoenix AZ
21 Wrangler Rubicon 4xe
The increased circumference means a lot more than the weight. If the weight was exactly the same it would still be much more work on your drivetrain with 37s. I wouldnt run 37s on 3.73, especially offroad without the Rubicon transfer case.
Must be early 392, they come with 4.56 now.
JT1
Broken Arrow, OK
2021 Willys Gladiator
I did an axle swap on my sport…was told they were stock rubicon axles with 4.10’s….turns out they were 392 axles
Ahhh, that makes more sense.
I have a gladiator on 37s, and it was miserable with 3.73s. Mine's a 6spd though. It wouldn't pull 5th gear until about 80. Running 5.13s now. If you see overdrive now with the 35s and don't mind a regear, give it a shot.
The diameter is more of a killer than weight. I have had 3 different 37s, and never noticed much penalty for weight (KO2s, Pat MT-01s and MT BajaBoss ATs) but you will 100% notice the change in diameter.
stretch-bsn
stretch-bsn
Northern VA
2018 JLU
Okay…that does clear it up a bit. Honestly don’t even notice much of a difference from 3.45 gears that were in my Dana 30/35 and the 3.73 gears in the Dana 44’s. 8th gear is not something my Jeep is used to lol.
So I’ll stick with 35’s and one day when I have $2500 to drop on gears I’ll do it. Until then I’ll stick to not ruining my rig lol
SadRobot
Los Angeles
2025 Prius LE
I'm running 37s on Sport axles (D44 rear, D30 front) but re-geared to 4.88. My Jeep struggles sometimes and should really have 5.13s but I can't re-gear again until I upgrade the front axle to a D44. I can't imagine having 3.73 gears.
If you have an auto I'd say 4.88 is fine. If you have a manual I'd re-gear to 5.13.
Maverick909
I.E.
www.instagram.com
100% 3.73 gears are terrible for 37's. I mean 4.10s sucked with 35's. I would HIGHLY recommend 4.88 for 37's leaves good mileage and power. still off-roadable with the sport transfer case. Ive been wheeling my wrangler on the setup for the last 3-4 years. no issues.
JT1
Broken Arrow, OK
While I mostly agree with that statement, I honestly think if you have a rubi, or swapped a 4:1 TC in, I think 4.56s with 37s would work too.. 5th gear with 4.56s is the same as 6th with 5.13s. I find running at 85mph gets me into the second stage of the oil pump.. having another gear lets me run 85 without getting 10mpg.
SadRobot
Los Angeles
2025 Prius LE
Hmm well I guess I'll learn soon enough. I'm hoping to install my Rubi t-case by end of October.
On another note I don't think I've ever gotten my Jeep up to 85 mph. 😂
JT1
Broken Arrow, OK
With the manual, the deeper gearing offroad is REALLY needed.
With a 4:1 TC, you can sacrifice some axle gear and actually be able to cross an entire intersection on-road in 1st gear. lol.
SadRobot
Los Angeles
2025 Prius LE
I'm told with a 4:1 you can just put the Jeep into 1st and it will actually crawl up things without touching the gas pedal. That will be a first for me to see that happen.
JT1
Broken Arrow, OK
My gladiator does that now with the 2.72 and 5.13s. I really only need to hit the gas to bump ledges or climb out of the water (or get a little heat in the tires). I normally run in 4L 4th between obstacles..
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
If you manage to get it up to 88, you're going to see some serious shit...
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
Having a diesel helps that a lot.
