Movement in drag link ends
MazMob
Maziar
Raleigh, NC
JLUR
Hello everyone,
I bought my first Jeep (JLUR) with manual transmission a few months back and it has 2400 miles on it currently.
The jeep was parked and I applied some pressure with my hand on the drag link and I noticed a small movement and clicking sound at the ends, it seems like it needs to be tightened up . I wanted to ask you if that is normal? my tie rod is tight with no movement at all. Let me know what you think...
Thanks,
Maziar
Jeepsterfreak
Honda, Future JLU
Hello everyone,
Thanks,
Maziar
When you move the drag link, do you notice the pitman arm moving? If yes, then it could be due to play in the steering box.
It wouldn’t hurt to check the torque on the drag link bolts.
MazMob
MazMob
Maziar
Raleigh, NC
JLUR
I just checked it seems like the joints are moving, the pitman arm is fixes. I'll check the torque also
Jeepsterfreak
Honda, Future JLU
Well this is interesting and could be an additional cause of all the reports of steering wandering and dead spot in the steering wheel. Do you exhibit any of those symptoms?
You should post in one of the many steering threads. You might be on to something.
nh4x4jeep
Jon
Grafton, NH, USA
2018 JLU
@MazMob - Hi Maziar! I noticed the same thing in my Jeep and wondered the same thing! I posted a video of mine at the following link:
Drag Link Loose?
Did you ever find an answer to your question?
Do you (did you) have loose steering, wandering, or death wobble?
~ Jon
grandsrus
DFW, TX/ Melbourne, FL
2019 JLUR
Aerospace
Drag Link Loose?
~ Jon
Very interested here. I have the popping at the Pitman arm link/joint. Thinking bad drag links from factory?
grandsrus
2019 JLUR
Aerospace
Update, i replaced my drag link with synergy's link and the stock unit was sloppy and loose at the axle end at 5,000 miles. Drives better but still dialing in.
@CBEUnion
Connecticut
www.youtube.com
18 JLU, 18 JL, 21 JL
I have the same issue but not going to bother trying to get any help from Mopar. Ordered a replacement/ upgrade from Metalcloak.
