IronWarjack
Not sure where this post should go.
I have an Auxbeam 8, I have watched countless install videos and the mounting bracket that came with it is simply unusable (perhaps by me).
I need a flat one similar to this:
I know, "you should have just bought the sPod", but its well out of my budget. This specific bracket not only reaches the 2 existing driver's side bolts, but lays over all the other parts in that area. The Auxbeam, if you are unaware, has an L bend and needs to be bolted into the side of the engine wall, under and behind the washer lines and a quarter sized metal tube (I think part of the turbo system).
I'm looking for anyone with advice or suggestions on a compatible mounting bracket that is known to work. The one pictured might, but I have no evidence it does.
