OldGuyNewJeep
I’m reposting my review from the 2dr thread so that it comes up in searches.
Original, in case you want to see any answered questions that came up there:
https://www.jlwranglerforums.com/fo...sions-master-thread.2951/page-757#post-315448
P#68358392AB
I don’t believe there is a different P# for 2dr, even though Quadratec told someone that there is. Clearly this P# works just fine for my 2dr, anyway.
OK! The sun’s out, and my windows are now stored in my new MOPAR bag and stuffed in the trunk.
@Quadratec @WestKY
P#68358392AB
- The bag’s design is fantastic. I know there’s a mom and pop outfit making custom bags, but I’d be shocked if the side windows fit in it as nicely as they do in the MOPAR offering. I’ve seen the Smittybuilt one, and this one is a much nicer fit, IMO.
- It’s a very tight fit in the 2dr trunk. You have to sorta curl the sides a bit, and only time will tell if that creates creases. I don’t think it will, but if it does the hot sun ought to sort them. (Update: After 3 days in the trunk I took them out and they were perfect.)
- Getting the top all the way down is extremely tight. I ended up folding my back seat forward ever so slightly, locking down the top, and then locking the back seat upright. The plastic corners of the side windows are sandwiched between the back seat and the top’s support bar. It doesn’t feel so tight that it’s going to be a problem, though. I’m sure it all fits more easily in a JLU. (Update: to unlock my top I had to reverse this process: slightly fold the rear seat, unlock and raise top, return back seat to locked position.)
- If not obvious, the bar from the bottom of the back window stores right in its bracket. Do not try to store it in the bag. See picture, below.
- I use Velcro straps to keep my top snugly in the down position. I feel this removes some play and will prevent friction between the window bag and the top. Also, it looks better and I'm anal.
@Quadratec @WestKY
