Some Random Guy
- Sep 16, 2020
- Washington
- 2022 JL Sport, 2022 Ford Mustang
- Occupation
- Comptroller
Yeah, I don't know my LED's enough. My understanding though is that if the LED is producing light, it's resistance is basically 0. There's only a super small voltage window where it is allowing current to pass, but actually presenting resistance. This is why in basic circuit stuff you just account for a Voltage Drop (which has no bearing if trying to measure peak current). Regardless if 5A are flowing or 25, the Vd stays effectively the same.I don't think LEDs have static resistance, the resistance changes based on the input. Sucks, cause that'd be the easy way P=V/R.
Using voltage drop like your first example is a great option.
Little archaic, but another option, from the amazon pic, looks like it's running a green (30 amp) fuse. Swap in a couple smaller 50 cent fuses, and it'll blow when you get below the current (of course turn the switch off when swapping).
