WranglerMan
- Will
- May 8, 2018
- Greenfield Indiana
- 2018 Wrangler JLU Sahara
- Occupation
- Retired
- Vehicle Showcase
- 1
Yes the Genesis wire accessory automatically connects the two batteries as one on startup I believe but I don't have that, the Gen 3 sys that they offer gives you (3) options on how they connect and I have the Gen 2.Not exactly. Current is measured for only the battery to which the IBS is attached. Most IBS calculations rely on current (A) data. The IBS does measure parameters that are effectively the same for both connected batteries, but for all intents and purposes it's only tracking one battery.
Also, the Genesis relay/solenoid potentially causes the IBS to not see any starter load, which likely affects its resistance calculation (I suspect the Genesis ignition wire accessory fixes this starter load "problem").
