Lug pattern and pressure sensor question
JohnHart
Gloucester, VA
2018 Wrangler Unlimited Sport
Need help ordering wheel and tire combos.. I just bought a jeep wrangler JL and tried to order Wheels and tires for it. Is the Lug pattern the same from the 2018 JK models as the 2018 JL models and is there any reason why i couldn't order a wheel and tire combo for a 2018 wrangler JK? are the tire pressure sensors the same? any info would greatly appreciated.
jericbarg
Rainbow City, AL
JLUR-Granite
Healthcare
The lug pattern / wheels are the same. Lug nuts are different JL is 14mx1.50.
TPMS sensors are the same also. OEM #68241067AB.
The 1st set I installed on my JL Sahara was from a 2017 Rubicon, fit perfect except had to change lug nuts.
Rubi-Zero
Nashville, TN
JL Rubicon , Audi S5
You couldn't use your stock lug nuts for the JL to install the JK Rubicon wheel?
jericbarg
Rainbow City, AL
JLUR-Granite
Healthcare
Yes I did use the jl lug nuts, I meant that was the only item different from the 2017. Jk lugs are SAE 1/2-20 and JL are metric 14m-1.50
