LIGHT MOUNTS?
Ear Responsible
2025 Rubicon x
HI CAN I SEE YOUR A PILLAR LIGHT MOUNTS AND WHAT YOU HAVE MOUNTED TO THEM. LOOKING FOR AMBER LIGHTS. CAN I MOUNT LIGHTS TO THE STEEL BUMPER USING THE BOLTS THAT ARE THERE?
I just purchased a set of KC gravity lights which are a bit large and I am in the process of trying to decide where to mount them on a Rubicon with a steel bumper with winch in place. The mopar mount will not work with a winch and I found an option on Etsy that places the light away from the winch but it partially blocks the headlight beam. Placement options are limited so I’m probably going to enlarge the existing holes on the bumper closer to center. Will also be running them off the accessories port on the zeon winch which is plug and play and can be controlled remotely with no wiring harness
jadmt
jeff
montana
truck trix $79 hoop...might be worth a try if you have mopar mounts...
Jeep Wrangler JL LIGHT MOUNTS? tempImageT9uBzR
Jeep Wrangler JL LIGHT MOUNTS? tempImageskCrHG
yokramer
Snark Incarnate
jadmt
jeff
montana
Those look like a good solution. Just a bit concerned about blocking the radiator however
I have been to Moab 2X (june last year and June this year) in 100° heat traveling ~800 miles one way at 80mph without issues either time...my coolant temps never change. lot of mountain passes in Montana and never had an issue..
Ear Responsible
2025 Rubicon x
Great thanks for the heads up. I could not find that particular model online. Do you have more specific info on where to obtain one?
yokramer
Snark Incarnate
Perfect example, I got bored about 47 seconds into the video, Nobody listens to me here so no reason to think trying to be a YouTube influencer is going to go any better.
You wouldnt be the first person to make videos no body cares about dont let that stop you.
jadmt
jeff
montana
Scott97
Maine
2024 Willys 2 Door Anvil MT, 2022 Ram Rebel
Mech. Engineer, Semi-Retired
Nacho Quatro 4" lights. White ones up on the A Pillar, using DV8 brackets. Amber down low on the Rugged Ridge Venator bumper, two on top, using two bumper bolts and two in the factory fog light positions.
Jeep Wrangler JL LIGHT MOUNTS? 20251015_074806 cropped
Jeep Wrangler JL LIGHT MOUNTS? 20251015_074814, cropped
