LIGHT MOUNTS?
Thumper291
Al
Massachusetts
2018 Jeep JL
HI CAN I SEE YOUR A PILLAR LIGHT MOUNTS AND WHAT YOU HAVE MOUNTED TO THEM. LOOKING FOR AMBER LIGHTS. CAN I MOUNT LIGHTS TO THE STEEL BUMPER USING THE BOLTS THAT ARE THERE?
yokramer
Snark Incarnate
I USED THESE AND REALLY LIKE THAT THEY SIT LOW AND OUTSIDE AND RE USE THE FACTORY BOLTS. I JUST PUT CHEAP LIGHTS ON THEM CAUSE I NEEDED SOMETHING QUICK.
https://a.co/d/0VGukw1
Jeep Wrangler JL LIGHT MOUNTS? {filename}
Jeep Wrangler JL LIGHT MOUNTS? 1760622910200-4k
Jeep Wrangler JL LIGHT MOUNTS? 1760622941428-yk
Aonar
N.W. Iowa
2012 Rubi and Snazzy 2021 JLURD
moabman-OG
Moab, UT
Jeep Wrangler JL Unlimited Rubicon
YOU CAN DO WHATEVER YOU WANT THIS IS AMERICA AND YOU'RE AN ADULT, UNLESS YOU DO SOMETHING THAT SOMEONE DOESN'T LIKE THEN YOU'RE RACIST. THANKS FOR READING. HAVE A GOOD DAY.
TEAMSLO
North Las Vegas
23 392, gone 21 JTM & 22 JLURD
I guess it depends on the weight of the light. I tried a few in the past and ended up with these mopar ones on my last rig.
Jeep Wrangler JL LIGHT MOUNTS? 20220910_115514
On my current rig, I have the AAL for now. Also, when I had the oem steel bumper, LP6's rattled a bit on the steel bumper. Others may have had a different result, no rattling now with the AAL bumper and mounts.
Jeep Wrangler JL LIGHT MOUNTS? 20250928_174726
ORACLElights
Peak Sponsor (Level 2)
Metairie, LA
www.oraclelights.com
2019 Jeep Wrangler JL
Automotive LED Manufacturing
YES AND WE HAVE MANY LIGHT MOUNT OPTIONS, WE'D BE HAPPY TO HELP FIND THE PERFECT LIGHTING SOLUTION FOR YOU. WE ALSO HAVE DISCOUNT CODES FOR FORUM MEMBERS: WRANGLERJL10
LIGHT MOUNT OPTIONS INCLUDE SINGLE MOUNT, DUAL MOUNT, ROOF MOUNTS, ETC. WE LOVE JEEPS!!!!!
Speed331
Sean
Las Vegas, NV
2008 Jetta, 2018 Discovery Sport, 2020 Wrangler Sport S (on order)
There is also a way to mount a fairlead bracket if you're running a winch. Gives the lights a 'classic' look.
Jeep Wrangler JL LIGHT MOUNTS? 20250604_102538(1)
Jeep Wrangler JL LIGHT MOUNTS? 20250426_184114
Jeep Wrangler JL LIGHT MOUNTS? 20250426_184243
Jburton
Justin
Wisconsin
2024 4-Willys
Same as some others, still trying to get amber covers but Northern Lights Bars are all sold out.
Jeep Wrangler JL LIGHT MOUNTS? 17607086956033588139239997545963
Wbino
NJ
Terrymo
Terry
2023 JLURXR 3.6 ET
They look good, but did companies use to make things w/o putting their name on everything?
I can't even watch baseball anymore with the adverts on the backstop.
Rant over....for now.
I know right? I blacked out their logo with some flat black Rustoleum. Almost every other logo I’ve deleted or blacked out when possible on my Jeep.
TravelerTheJLU
Hunter
North Carolina
2023 Jeep Wrangler 4xe Rubicon 20th Annv
YES YOU CAN MOUNT TO BUMPER!!! I have these small "marker lights" mounted. I also used a similar mount on the A pillar to everyone else, they're cheap about $20 but work well.
Jeep Wrangler JL LIGHT MOUNTS? 800A8150-9081-4A4B-BB96-AC4DD02EC2EF_4_5005_c
Jeep Wrangler JL LIGHT MOUNTS? D89A1125-6171-460F-8DFD-EBEA301145E2_4_5005_c
yokramer
Snark Incarnate
