Let's Talk Tires. 35's, to Be Specific
TJ01
TJ
Pittsburgh Pa
Jeep wrangler JLUR
Agreed, this looks good. Which wheels are those?
I ordered the same tires yesterday.
Raceline clutch wheels. 17x9, 4.5” bs, and 0 offset. Let me how you like those tires. Its a mopar 2” lift also.
aug0211
Ohio
JLUR 4xe
I knew I recognized the wheels. Thanks! I'm considering another raceline wheel. I'll let you know how the tires work out - it will be a while though, because I don't even have the JL yet :(
TJ01
TJ
Pittsburgh Pa
Jeep wrangler JLUR
Lol i dont have mine yet either. Got told today its in route to dealer. Has ETA of april 15-20. Im curious if the soft top is with it or it will show up later.
aug0211
Ohio
JLUR 4xe
Tires have arrived at the shop... ordered 7 different wheels last night to take a look at in person. Will return the 6 I like least and order 4 more of my top pick.
Then I just need the Jeep!
Correction - ordered 8 wheels, lol.
Here’s a link to the post where I share which wheels I bought to sample:
https://www.jlwranglerforums.com/fo...ations-granite-sahara.4640/page-3#post-138165
TJ01
TJ
Pittsburgh Pa
Jeep wrangler JLUR
Anyone know if they fixed the issues with mopars lift? (Bowing in coil spring) and does anyone know how tall the jeep is with 2” lift on?
Goblue
Darran
JLU/OB
FF/PM
Yes fix is in they have a thread about it in today's post...what tires are those you all are getting...I will be a DD and this is my first jeep. So kind of want best of both worlds....no lift just stock JLR so far
TJ01
TJ
Pittsburgh Pa
Jeep wrangler JLUR
4/15-4/20 NOT 2/15-2/20. I orderes on 2/22
TJ01
TJ
Pittsburgh Pa
Jeep wrangler JLUR
Im going back n forth between teraflex fromt spacer to level out and go 35’s. Bc i just think 37’s will kill my power to much for the hills around here.
jeeperskeepers
adrian
San Diego
Wrangler JLUR
I'm 100% sure now, after seeing the JLUR today at the Indy Auto Show, that I'm going to upgrade to 35's. I'm looking at 3 tires, and the favorites are in this order, with pros/cons:
1. BFG KO2 315/70/17 Load Range C....Pros: price (256), weight (64 or 65 pounds), Cons: 15/32 tread depth (Not bad, but not as deep as Duratracs, C range should ride nice, but are the sidewalls as tough as the E rated BFG's? If so, then it is a pro.
2. BFG KO2 315/70/17 Load Range E...Pros: price (276), weight (64 or 65 pounds), tough side wall, Cons : 15/32 tread depth, maybe a little stiffer ride than the C's (better handling though?)
3. Goodyear Duratrac 315/70/17 Load Range D...Pros: load range D is a good compromise, weight (63 pounds) 18/32 tread depth, more open tread, almost like a mild mud-terrain, Cons: price (309 ouch!), Some say weak sidewall is more prone to cuts than BFG KO2, said to get noisy with wear, and sipes disappear sooner than KO2, supposedly.
Here's the great news: I'm taking the 285 KO2's off my JLUR and putting them on my JKUR, which happens to need tires! I'm ordering some Quadratec Hard Rock wheels, black with polished lip. They should fit the 285's better than the stock Jeep Moab wheels on it now. It already has a 2" lift, so it should look and perform well with these new shoes!
I looked closely at the standard plastic rear bumper on the JLUR today. It looks like it has room to clear the 35's, but it will be tight.
Which of these would you choose? What tire are you looking to get, if up sizing? Pros? Cons? Other tires I considered were KM2's, Nitto Trail Grapplers, and General Grabber XT's. I just have a hard time getting away from BFG, since they have served me so well, so long, especially off road.
jeeperskeepers
adrian
San Diego
Wrangler JLUR
After reading many posts on the subject and finding no reports to the contrary I went ahead and replaced my factory JLUR KO2s today with KO2 315/70-17s (C) today @ 35psi. There was an immediate ride improvement - much less harsh and altogether a smoother ride. This continued at freeway speed and also did not stray from the direction of steer - even on grooved surfacing. Altogether it’s a more compliant ride and no change in road noise - and now the tire proportions look much better. No detectable problems-option 1.
DanW
DanW
I took mine off road today for the first time, and the KO2's were just as outstanding in the mud, sand, and rocks, as they are on the road. They are impressive under all conditions. Best tire I've ever had.
Brad41
S. Indiana
18’ JLUR firecracker red
That’s good to hear, thanks for the report. I’m planning on going this route by having my dealer swap tires when mine comes in.
BaldEagle
Seth
Los Angeles
2018 Black Jeep Wrangler Rubicon jl
Correct it will only add 1 inch overall height to the jeep. The tire itself is 2" taller.
If you add 2,5 inch lift and 35 what do add to figure total extra height
