Compression-Ignition
My wife's JLURD was a little over an inch taller in the front than the rear. The shocks are the same length. 26" rear & 23.75" front. Could be valved a little different, but I don't know. I suspect the swaybar links are different, based on the fact that the ones I got in my cheap teraflex 2.5 spacer kit seemed way off. I put the ones they sent for the front on the rear and didn't use their fronts. Then I used the factory rears in the front (after some redneck engineering).
I cut the front spacers down an inch so the nose of the Jeep wouldn't be pointing at the sky. The Jeep is still a little nose high.
I don't think that backspace will work all that great stuffed. Clearances get real tight with the 37's so you need to be ready to hack some stuff or your bump stop game better be really really on point.
We don't have the extra weight of a winch up front, but the 5th 37 and wheel hadn't showed up yet either. And you can tell it's still a little higher in the front. The teraflex kit said it was a 2.5", but it came with a 3" front and 2.5" rear. Hence why I cut the fronts down.
It rides pretty good. Waiting on new shocks and steering stabilizer. The factory shocks definitely can't handle the extra weight of this combo.
