Radavi01
Anyone know if the OEM Halogen vs. LED headlight housings (or buckets) are exactly the same? Size, connector holes, and everything else?
I am trying to fix 3 broken tabs on an OEM LED headlight. To do that, I want to buy a cheap halogen light just for the bucket, then swap my LED setup directly over to the halogen headlight housing. My plan will only work if both housings are identical.
I will post the results of this experiment. Cheap way to fix broken headlight tab if it works.
Thanks in advance!
Thanks in advance!
