LED Package vs Oculus Bi-LED headlights
JNJ
Jodi
Lowell, ma
2022 Jeep Wrangler Unlimited Sahara 4xe
I know the OEM LED headlights from the LED package are great and I also know the Oculus Bi-LED headlights but is there a reason to switch the OEM ones for the Oculus? I can always sell the one not used.
TIA!!
rohdawg
Long Island, New York
Merchant Marine
No.
DanFelix
Riverside, CA
2018 Wrangler JL Sport S, 3.6l
I have the Oculus and I am very pleased. But, I would not switch if only to avoid adding complexity to your wiring system. In the long run you will not notice the difference.
rohdawg
Merchant Marine
Running a wire from the headlights to a fuse isn’t all that complex.
There’s absolutely no reason to get rid of OEM LED headlights for an aftermarket set. Unless you prefer the look of the Oculus I guess.
WRGLR-JL
PA
2022 Willy's 2 door
I'd stick with the original LED's. Work great and look great! Don't know much about Oculus performance but it probably is not equal to the original equipment. My 2 cents.
ORACLElights
Peak Sponsor (Level 2)
Metairie, LA
www.oraclelights.com
2019 Jeep Wrangler JL
Automotive LED Manufacturing
I agree the OEM lights do perform well and they are expensive. However, ORACLE did do a wall test comparison of the Mopar light vs the Oculus. The output, cut off, and overall throw of the light was in favor of the Oculus. Feel free to look at the photos below.
Jeep Wrangler JL LED Package vs Oculus Bi-LED headlights wall_test_3_1024x1024
Jeep Wrangler JL LED Package vs Oculus Bi-LED headlights wall_test_2_1024x1024
rohdawg
Merchant Marine
Don’t misunderstand what I’m saying.
I’ve had the Oculus Bi-LED installed pretty much since they were released. I’m very happy with them and the cutoff is phenomenal.
That said, my Jeep was equipped with the garbage halogen lights - so an upgrade was necessary .
If my Jeep had been equipped with OEM LEDs, I’d have waited until I had an issue before I tossed a pair of $1000.00 dollar headlights to the side.
?? that’s as of 10/21/22
Jeep Wrangler JL LED Package vs Oculus Bi-LED headlights 63A78F0D-2902-4017-B8F2-035233016A6A
ORACLElights
Metairie, LA
I completely understand! Right there with you!
:like:
Jtclayton612
Memphis, Tn
2020 JLU Sport S
Whenever I make the move to PA I may invest in the oculus heated lights. Otherwise the LEDs in the halogen reflector work pretty well for me.
TheRaven
Reading, Pennsylvania
Sold
I'm a big fan of the Oculus setup - there's no question it is significantly better than the OEM LEDs. However, I don't think I would go through the trouble to upgrade FROM the OEM LEDs. With headlights there's this "good enough" line that once you are over, increases in performance lose a lot of their benefit. The stock setup is more than good enough.
Xorak
TN
2020 Hellayella Sport, 2023 Reign Sahara
I have both sets in different Jeeps. The Oculus are superior in every way. I would not swap the OEM LED headlights out for them though. The OEM lights are decent.
Santo
Calgary
2023 Jeep Rubicon Extreme Recon
:like:
Do you have to change the computer with Tazer to accept Oracle LED from Halogen? I heard some say you do due to flickering and others say you don't with the Oracle Oculus? Thanks
ORACLElights
Metairie, LA
For the OCULUS headlight you do not!
