Larger Rear Storage Cubby
Glamisfan
Glamisfan
SoCal, 30 minutes from Glamis
2020 Sting-Gray JLUR
I finished mine up this past weekend. I’m very happy with the way it turned out. I did a 1 Hour drive in 110° heat, and I checked the temperature on the box when I got home. Bottom of the box was 135° and the top driver side corner that’s very close to the exhaust was 165°. I figured it would be too hot the way it was. So I had some exhaust wrap and some fiberglass backed aluminum foil exhaust heat shield from past projects, so I wrapped the exhaust and then screwed the heat shield onto the stock shield that I had cut up. Need to drive it and see how hot the box is now. I did have the storage boxes in it on that initial drive, and there was no damage to them.
Jeep Wrangler JL Larger Rear Storage Cubby IMG_5763
Jeep Wrangler JL Larger Rear Storage Cubby IMG_5764
Jeep Wrangler JL Larger Rear Storage Cubby IMG_5761
Jeep Wrangler JL Larger Rear Storage Cubby IMG_5762
teedublya
Tim
2023 JLUR
Espar B2L? How did you route the outlet hose?
That's right. Routed outlet hose over driver-side frame, then into insulation and up behind tail light. I had to cut a hole in the ceiling of the tail light compartment and plastic trim. It was all a tight fit but turned out well.
THAW
Foster
23 JL4DrRubicon
Nice. How do you like the heater?
And did you tap the gas tank through the fuel pump/level unit?
teedublya
Tim
2023 JLUR
I can't give much feedback on the furnace yet since I only ran everything to test it. I'm hoping to get a lot of nights in the Ursa Minor this summer and get the Espar dialed in. The unit seems high quality.
Espar makes a 90° pick up tube that fit in the fuel pump assembly and cleared the tub.
