JLURD fuel tank problems - part deux
drick
AZ
2016 JKUR & 2021 JLURD
sales monkey
Did another search on this, and didn't see anything else aside from my original thread (https://www.jlwranglerforums.com/forum/threads/2021-jlurd-diesel-overflow-leak.83612/) on the topic.
So just when i thought i had the original problems sorted on this topic - here we go again.
As we continue to grind through the evolving weather patterns here in AZ (i.e. 30 + days of 110 degree weather, with another 30 of 100+) a new interesting and unwanted behavior is coming up again on the rig.
I am seeing similar issues here with the new tank, wondering if others are seeing the same?
Context
Tank is down any amount
Weather is 100 degrees plus
Rig may be parked outside or in our AC controlled garage
Symptom
Go to put diesel into tank, and the filler clicks off immediately as if tank is full
Workaround (which is the same thing i had to do before the tank was replaced)
Pull filler nozzle out most of the way, fill manually very slowly - cannot use the auto fill option / lock tabs
My uneducated observation here is that somehow this is workaround letting air and(or) pressure out of the tank that the high temperatures here are causing.
I wonder aloud if the Jeep/FCA engineers modeled a scenario where the rig gets to 130-140 degrees sitting outside, then is operated in the ~110 degree heat, which dumps even more stress on the vehicle systems.
Is anyone else seeing this on the JLURD, and if so any other ways to address it?
TIA
D
RocknJL
Idaho
2020 JLURD
I am currently having problems filling mine as well and am unsure if it’s the pumps around here (they seem to flow higher than normal) or if it’s the same problem you are experiencing. I can’t use automatic cutoff half to barely pull pump handle to fill. It’s been in the 90’s around here. This is new as I’ve had the Jeep for around 25000 miles with no issues in similar heat. I will update once I get her home and try the standard pumps as I’m currently on vacation.
garykk
Gary
Southern NM
2022 JLURD
Have you removed the discriminator ?
RocknJL
Idaho
2020 JLURD
Haven’t touched mine it’s on my todo list but it’s stock for now.
