dannko
- Dan
- Aug 14, 2018
- Bee Cave TX
- 2018 Rubicon JL Unlimited
Received my Rock Krawler adjustable upper control arms for my 18 JLUR, has Mopar lift, but already replaced isolators with USA Alloys, replaced track bar with Rock Krawler adjustable, replaced damper with Falcon 2.2 adjustable, but would like to add about a degree of caster, so adding these arms.
Here is the question, without having to do a lot of trial and error, does anyone have an exact calculation of incremental inches changed to degrees? Example if I shorten it 1/4" what degrees of caster should that add?
Also, can I just switch the upper arms without loosening all the suspension bolts and then retorquing all? I have to say, that torque job is just too hard on an old man laying on the ground. I figure I can just swap one arm at a time, then torque the arms up after I have both installed.
