JLU TPMS after tire popout
ahmadtaha1988
ahmad
dubai
2023 JL 4 door Sahara
Hi all,
One tyre popped off the rim while dune bashing. Came to a stop within a few meters and nothing should be damaged.
That particular sensor shows "--" on tpms screen now and tpms light is one. I suspect some software confusion. Any trick?
Rhinebeck01
Ormond Beach, Florida
Retired at 55 ..
Hi all,
Well, if that TPMS did not get damaged and now is not serviceable....
...Try inflating all on the ground tires to the exact psi mentioned on the drivers door placard... Now, drive for a mile or 2.
IF/ when all TPMS show up, then set the psi on your tires, to the psi you normally run with..
Maverick909
I.E.
www.instagram.com
my assumption is that the sensor is clogged with the fine sand or the sensor is broken. typically when we see a tire de-bead or come off the rim the sensor takes on damage.
ahmadtaha1988
ahmad
dubai
Can you buy just 1 sensor? Anyone has the part number for a 2023 JLU? Thanks
Rhinebeck01
Retired at 55 ..
