roaniecowpony
I just rotated my tires. Is the JL a self-learning system, or do I need to use my relearn tool and a procedure?
Yes, all the tires have 433mhz tpms sensors. The 4 on the ground will be read, the spare won’t, rotate the spare into the mix and it’ll be picked up. The one the spare replaced will no longer be read in the spare locationHow about the spare, if you rotate it in does it have tams and will it learn?
Cool! I suspected it when I drove it a couple blocks and the pressure readings changed. But, I couldn't verify which actual tire was giving the readings in the respective locations on the display.Auto relearn
It does it automatically...I noticed when the dealership pressured my tires up to 52 psi! When I first drove the drivers front tired was still at 37...then after driving a bit it jumped to 52. So they obviously inflated them after the rotation, but not the spare. I immediately went to deflate them...annoying...but was cool to verify they actually rotated them as I askedI just rotated my tires. Is the JL a self-learning system, or do I need to use my relearn tool and a procedure?
Well TPMS batteries can go bad. Impossible to do a relearn without driving the Jeep. Sometimes though literally driving in a few feet in the dealer parking lot will work. There are two other types of relearn, use of a trigger tool like in Fords where you have a little garage door opener type device and an OBD relearn. Neither can be done in a Jeep.Here's one for you. After 5 tire rotation done by a 4x4 ship my passenger front tpms (previously the spare) keep coming in and out so I took it to the dealer, they tested the signal on all 5 and the driver rear wasn't transmitting and after they replaced it I haven't seen the issue. I guess the computer freaked when one of four was missing and reports what it wants. Dealer said they did a relearn but the Jeep didn't have any miles on it so I guess the dealer has a magic button.
A little off topic but if doing a 5 tire rotation, what goes where?
I do this one too.
