JLSCAN how change LED?
northshoremb
Nick
SSM, Ontario, Canada
2019 Wrangler 2 door
welder/ 575 ton crane operator
Have VEEPEAK BLE+ with serial number subscription. JLSCAN app which seems to work for seeing codes or all the parameters but can't get the LED thing to work. I go into Headlamps for high and low but selecting Active just thinks for minutes then fails.
Jeep Wrangler JL JLSCAN how change LED? Screenshot_20240616_125051_OBD JScan
Jeep Wrangler JL JLSCAN how change LED? Screenshot_20240616_125221_OBD JScan
Gregj
Greg
West Texas
Do you have a SGW bypass? The Jeep has a Security Gateway that you need to bypass to make changes.
Gregj
northshoremb
Nick
Gregj
No idea what that is. You .Ean I now need to purchase another thing for it to work?? 🤦🤦🤦 So I can't just plug into the OBD2 and use?
Gregj
Greg
West Texas
richk225
Rich
New Jersey
2021 392Rubicon XR 2017 Jeep Grand Cherokee
retired due to broken back
Gregj, How are you? have you made any progress on the intrusion alarm? I just received the new (used) module from the UK.
Do you want me to send you both of mine so you can give them a try?
According to mciaio/ Michael he believes that both modules would work.
Please let me know, it`s no problem for me to get them out to you
Gregj
Greg
West Texas
Mine should arrive this week so that project has been on the back burner. I did install a Voswitch JL300 in the truck and some lights on the bumper yesterday. Also changed the plugs in the Boss Lady’s Jeep.
Jeep Wrangler JL JLSCAN how change LED? IMG_8240
Jeep Wrangler JL JLSCAN how change LED? IMG_8242
Taking it easy today. Still have lots of other things to get done.
Gregj
richk225
Rich
New Jersey
Great minds must think alike lol
i have a Voswitch JL800 to put in along with a whole lot of lights. Are you looking for any lights or accent lighting?
I have some red and blue leds that are similar to the lights Rockstar engineering using on their steps. I can get Some pictures to you if you want. I would say I have a little too much in the lighting department lol
Jeep Wrangler JL JLSCAN how change LED? BCC11496-BE6B-4855-80DC-55486F0840E9
Jeep Wrangler JL JLSCAN how change LED? 8E8047EF-4357-44B0-A060-690C5FC7E172
Jeep Wrangler JL JLSCAN how change LED? 1862A76F-A983-4AEA-B84C-BF5BEBFF3FA4
richk225
Rich
New Jersey
What bumper light mounts did you use? I have a set of ARB lights I was thinking of using in that spot and all I could find was the Mopar light brackets for $125 for a pair
Gregj
Greg
West Texas
Those are the Mopar 5 inch lights. The brackets were locally and sustainably sourced (i made them) they use the bolt in the side of the frame for the bumper. The Mopar lights are pretty heavy, I probably should add some bracing to them, lol.
Gregj
richk225
Rich
New Jersey
The ARB lights have some heft to them also. But $125 for the Mopar brackets and not knowing the quality of them? Will they strong enough to keep the lights from moving around? I also bought a set of Gatekeeper spindle mount light brackets that are still in the box
Now I wish that I had made my own because it would have cost a hell of a lot less and I would have been able to mount them further away from the tire which would give it more of a steerable light.
At first I was just going to use the hole that is already there with the brake line going to it
