JL 392 LUX Rock Light Install (3 Zone Controller Box)
Myrddin
Southern Indiana
2021 Jeep Wrangler Rubicon 392
Hello :) looking for some pic's and advice as I plan out my install. Can you folks share where you put your controller box (if you did this install). I already have an AMP Step controller box in the tiny space between the battery and fender area. Not much room for more stuff (trust me I am not complaining). Before I start removing stuff to find a less interesting place to stick the box, I thought I would ask and hope to see some pics. I'm shooting for a factory like install... So far, the only spot I see that is easy to get to is the area on top of the battery... I'd like to find some place that makes it seem like it was part of the original concept and have it in an area that is still serviceable (if I add more lights or change up something). Also, Thoughts on outside the frame rail vs inside the frame rail... reading about recent rock light installs, it looks like lots of folks use the frame (I wouldn't have done this in the past) instead of chasing a wire harness or adding the zip tie mounts down the frame to route the light wires. I have an 8 light RGB kit... going to install just like the LUX diagram recommend. each corner (end of the frame) and two between the wheels. Thinking 2 zones? 1 for front and rear, and one for middle... still thinking this over.
anyway, please help a guy out... Pics are best as it will give me a better idea what it may look like after the fact... plus I know you folks are dying to post pics of your install ;) and I am looking forward to seeing them.
