Jeep Stimulus Program Checks
jludave
The Isle of Long
IT Manager
RenegadeJeeper
Michael
Edmond OK
2018 Stingray JLU sport
smittybuilt xrc10K with synthetic rope. at some point... maybe next tax return or black friday
I got mine on cyber Monday on eBay as the numbers were flipped... Should have been like 538 and I got it for 358 shipped....
If only I had purchased two or three to make some money hahah
Wabujitsu
Sarasota, FL
2021 JLUR, 2020 JLU Sahara
Retired US Army
take plenty of pics with the install! I've been eyeing the 2.5" JKS lift with the HD springs and fox 2.0s. Use my Check to pick up the EVO oil pan and trans skid plate for my JLU sport. rest is being saved up for a lift.
Brian, I just got my Jeep back tonight, with the JKS three inch lift installed. I LOVE IT!!! On-road handling was more comfortable, and my steering is still tight with no dead spot or wandering. I also took it off-road on the way home. Handling and comfort was incredibly great!
It’s probably just me, but it seems higher than three inches. Thoughts on that?
Jeep Wrangler JL Jeep Stimulus Program Checks 9880EAFC-67FC-4AF4-8F6F-42E47B3056A7
Jeep Wrangler JL Jeep Stimulus Program Checks 1A21A1D5-CE6B-41AD-822F-37FA4B8DED78
Jeep Wrangler JL Jeep Stimulus Program Checks 0D7C670C-4EFA-4CC3-99DA-897F30619381
Jeep Wrangler JL Jeep Stimulus Program Checks A7657824-54C0-4DB4-9D30-3F9C238F1CA1
Maverick909
I.E.
www.instagram.com
that came out great!. this looks like the kit i will be getting at the end of the year or start of 2021. thanks for the update!. the springs should settle in in a couple hundred miles or so and lower down just a hair. are thouse 35" tires? or well 315's? great looking setup!
Wabujitsu
Sarasota, FL
Retired US Army
Thanks Brian! They are 285/70R17s on 17x9 OEM rims, a fifth on an inch shy of 33”. They are typically classified as 33s, and I had the speedometer/odometer/transmission flashed for 33s. Please keep me posted on your lift; I would like to see before and after photos!
Maverick909
I.E.
www.instagram.com
will do. also that lift is larger because of the sport model. it ends up being like 3.75/4" lft for a sport. for what ever reason they base the lifts off the rubicon stock size which is roughtly .75"-1" difference
Wabujitsu
Sarasota, FL
Retired US Army
Brian, I talked to my mechanic again today. It was actually a 3.5” lift kit, which now makes sense, in light of what you said above. From my measurements at the front of the Jeep, it’s at least a solid 5 inch lift.
Maverick909
I.E.
www.instagram.com
Gotcha it should settle though. I’m shocked the 33” tires don’t look bad for that much lift. Thanks for the update!
