Shibadog
- Dec 28, 2021
- Bowling Green, Ky
- 2020 Wrangler Sport S hardtop
- Occupation
- Safety &Fire Protection Engineer (Retired)
LBL is mostly a mud run. Be sure whatever you rent has at least semi decent tires and you should be fine. Also be sure you clean it good, including the undercarriage or your friend at the rental agency will not be pleased. Also note that if you try anything too intense and dink the Jeep, YOU will be responsible…. Take easy trails and you’ll be fine.
