Jeep JLU Transmission 4x4 errors
Wheelstories
Dubai
Jeep JLU 2018
After getting my broken rear axle shaft fixed, I can see this is the next error code and my 4x4 is working too. No abnormal noise, Just the service 4WD message appeared on the screen. Those who have diagnosed have straightly advised for a transfer case replacement. Am confused and seeking advices!
Jeep Wrangler JL Jeep JLU Transmission 4x4 errors IMG_9820
JLeco2022
Anaheim, CA
2022 Wrangler 3.0 V6 Eco Diesel
take apart T-case and see if the ob2 is lying
JLeco2022
Anaheim, CA
here is a question, explain how the rear axle shaft broke, were you bouncing hard and a bunch of torque happened? were in in 4L 4H 2H? if its sloppy it could be worth taking apart because it could be a broken gear in the t-case
Wheelstories
Dubai
Jeep JLU 2018
I broke my rear right axles while driving at the beach, Unfortunately the tire pressure wasn’t deflated much. Could be a reason for this stress while driving on 4x4 low. And later when I found the rear wheels stopped working, tried taking out the vehicle on 4x4 auto and part time, and slowly they too stoppped responding. I had to tow the vehicle out as it was near the sea, And this could end up in bigger mess. Later I found, No gears were engaging (PRND) at any 4x4 or x 2 options. I took a flat bed and took it to the garage next day, Found rear axle broken and got it replaced. After that I can see this error, And none of the technician can figure out the issue rather than option a direct replacement of transfer case. I felt like, it’s something minor and can be figured out after dismantling it. What do you feel ?
58Willys
Geoff
Western Washington
2018 JL Sport
Have you tried to clear the codes? Codes may been set when axle broke and are just stored. Clear codes, if they return try a clutch relearn procedure.
