MattLaurence
So that is exactly the scenario, i was baffled by the precipitating factor which was simply engaging ESS. I was driving, going 20 or so mph, and coming to a stoplight I pressed the ESS button, which would have made it ACTIVE. I was driving straight, I had the clutch pressed in as I was coasting (which should prevent ESS from engaging), and the AC was off as I just had the windows open.@MattLaurence Matt:
This said, I am still curious to me why turning the ESS off button off, i.e. allowing ESS to possibly engage, caused your JL to crap out. I say this because this button being off is only one of many conditions that must be met by the vehicle's diagnostic for an ESS event to occur, not the least of such other events being the vehicle being motionless, the brake pedal pressed hard enough, the ESS battery having sufficient voltage, not being on a hill, the steering wheel not being turned, and others.
As soon as ESS was made active, the engine cut out and began clicking and I was dead in the water.
I daily drive the JL which is why I have 100k miles, but it is concerning that if the batteries are truly to blame, there are no subtle signs they are getting weaker, like a longer or slower crank at startup, headlight brightness that fluctuates, etc.
Anyhow, hopefully the issue is resolved. I'll post a pic of the work that was done by the dealer for reference for anyone else in a similar situation.
