Is there a problem with tap splice wire connectors
Zerokharma
Chad
Birmingham,AL
2020 Jeep Wrangler sport altitude
So I have some 3 inch cube lights on my a pillar. The lights can be wired up to the turn signals and the running lights. They are Auxbeam color play. I was just going to at least wire them up to the turn signals but after I bought some tap splice connectors I saw some people said not to use these connectors because they are not good. Just wondering if anyone has used these and are happy with them and if not what are your issues. Thanks
agentdr8
CA
21 JLU Willys
Wire taps don't provide the most secure connectivity and can lead to inconsistent behaviors. Usually they don't cut through the insulation on both sides of a wire evenly, so the tap is only in contact with a few strands from one side.
If you're just testing prior to making a more permanent install, they're probably ok. But I prefer using butt connectors over them, and would rather just solder and heat shrink over either of those 2 connector options.
mrtm1970
Marshall
Orlando, FL
2019 JL Unlimited Rubicon
Mechanical Engineer
Zerokharma
Zerokharma
Chad
Birmingham,AL
I might try the taps to see if I even like the lights hooked up to the turn signal before I try a more permanent route.
Thanks all
Nokones
Kenny
Sun City West, AZ
23 Rubi, 21 Silverado, 13 Grand Sport, Cayman GTS,
Unemployed For The Rest Of My Life from a career of spreading love, cheer, and joy to lots of special individuals that were asking for attention..
If the circuits that you are tapping into are part of the vehicle's CAN system/network more than likely you may be causing interference to the other devices/components on that network that very well could fail and that could be catastrophic.
roaniecowpony
Retired Engineer
T-taps and the like are really a shortcut that can be unreliable and even cut your OEM circuit. They are not allowed on light aircraft (or any aircraft for that matter), so that gives you an idea of their functionality and reliability. They are the devil's work, IMO. Just say no to T-taps.
roaniecowpony
Retired Engineer
bd100
USA Midwest
JT
Another method:
Cut 1" or so of insulation mid-stream in the wire, but do not cut the wire itself.
Poke the third wire between the strands of the intact inline wire.
Wrap the third wire around the inline wire, at least one wrap on each side.
Bend the third in the direction you want it to end up.
Solder. Be sure to heat everything enough that the solder is drawn into the joint.
Zip tie in place for strain relief.
Liquid electrical tape for insulation of the piece of abstract art you have created.
Standard electrical tape or friction tape or whatever around the entire bundle, for abrasion resistance.
Kind of an ugly result, but it works, and you haven't broken the original line.
roaniecowpony
Retired Engineer
Cutting into wiring is bad practice, IMO. Tapping circuits, if done at all, should be at the origination of the circuit, such as the Power Distribution Center (PDC) or fuse panel. Adding components to existing power circuits is bad practice. Use relays for powering lights or other components that need switched circuits. Stringing modification wires directly to the battery is bad practice. Use an ignition switched high power relay to energize a bus bar where all the component connections can be made.
Now, if I would follow my own advice, I'd be doing good.
Heimkehr
Pennsylvania
2021 JLU 2.0T
...after I bought some tap splice connectors I saw some people said not to use these connectors because they are not good.
Scotchlok wire taps, as they're known, are easy to use and destructive in about equal measure. As suggested, their design is such that the insulation may not be perforated correctly, which could in turn lead to erratic functioning.
Post #3 mentions what I'd do.
In a pinch, for testing purposes anyway, Posi-Taps are safer and proven reliable.
Zerokharma
Zerokharma
Chad
Birmingham,AL
Well I have been convinced to just take these back to Lowe’s. Don’t want to mess up my electrical just to have my cube lights flash when I turn on the turn signal
bd100
USA Midwest
JT
A turn signal on the side of the vehicle can be useful. If someone is in your blind spot they cannot see your front or back blinker lights. If your cube lights can shine blinker light sideways then they may be worth keeping and wiring up.
