KC HiLiTES
Rock Sponsor (Level 1)
Robert B.
Flagstaff, AZ
2020 Jeep JT, 1969 Wagoneer
Lighting Adventures Since 1970
This plug-and-play relay harness perfectly connects KC lights or other aftermarket lights to your Jeep's OEM headlight functions.
Designed specifically for 2018+ Jeep JL/JT models, this Headlight Auxiliary Light Adaptor serves as a trigger relay to integrate additional lighting with your Jeep's three headlight modes. Whether you're using your Low Beams, High Beams, or Halo (for models with Mopar LED Headlights), this adaptor makes adding LED lights easy. No need to splice wires or modify your OEM harness—it's a water-tight, heat-resistant, DIY solution that saves you time and effort. Just follow the simple step-by-step installation guide and hit the trails faster!
Features:
  • Engineered for Jeep JL (2018+) and JT (2020+)
  • Easy plug-and-play installation
  • Water and heat-resistant
  • Relay Trigger for:
    • High Beams
    • Low Beams
    • Halo Light (if equipped with Mopar LED Headlights)
What’s Included:
  • Wiring harness only
Fitment:
  • Jeep Wrangler JL / JLU Models (2018+)
  • Jeep Gladiator JT Models (2020+)
Recommended Light Pairing:
For optimal trail lighting, pair this harness with a set of FLEX ERA® 4 or Gravity® Titan™ lights. When connected to your High-Beam relay, you'll enjoy improved visibility and a better overall lighting experience. Or, pair it with the FLEX ERA® Fog Light Kit to take advantage of fog and off-road modes, all controlled through your OEM light switches. With this harness, upgrading your Jeep’s lighting is hassle-free, without the need for extra expensive switch units.
--- Link to Product Page ---
Jeep Wrangler JL JL/JT Headlight Auxiliary Light Adaptor 1726673012355-v6
KC HiLiTES
KC HiLiTES
Robert B.
Flagstaff, AZ
Congratulations! It's awesome to have seen this go from prototype to product!
Thank you so much! We couldn't have achieved this without the support of people like you and the entire community. This product was conceived right here in this forum, and everyone's contributions have been invaluable.
Terrymo
Terry
2023 JLURXR 3.6 ET
I think you meant to add…”And to show our gratitude we’re offering forum members a discount of…”
JL_Noob_22
Larry
Eastern, NC
2022 Sahara Unlimited
Yeah I was thinking $50 would be the max I'd pay for this.
NyRey87
Nyles
Reno, NV
2021 JLURD
Will this harness work for my needs, I swapped my halogen headlights on my 21 JLURD to a set of LED takeoffs from a 20’ sport and I can’t get the halos to function as the DRLS on the passenger side, I’ve tried everything in JScan, still no luck
KC HiLiTES
KC HiLiTES
Robert B.
Flagstaff, AZ
Hello @NyRey87
Sorry for the delay, If you upgrade from the halogen to the factory LEDs, additional wiring is needed and programming to get the halo to work, Once the halo works and is being powered you can connect this wiring to the halo function.
You can use this wiring in the link below
https://www.quadratec.com/sites/default/files/installation_instructions/K6862533AB.pdf
It would be Part A
Jeep Wrangler JL JL/JT Headlight Auxiliary Light Adaptor 1729040305238-8
NyRey87
Nyles
Reno, NV
2021 JLURD
Thank you for the response. It seems as tho Mopar 68347117AB Wiring-Jumper Harness has been discontinued
https://www.moparpartsgiant.com/parts/mopar-wiring-jumper~68347117ab.html
I had the right side Halo working through JScan but couldn’t get the left one working. These are the connectors for the left side. Any one know where I can source that Jumper Wiring Harness?
Jeep Wrangler JL JL/JT Headlight Auxiliary Light Adaptor IMG_9581
Jeep Wrangler JL JL/JT Headlight Auxiliary Light Adaptor IMG_9580
KC HiLiTES
KC HiLiTES
Robert B.
Flagstaff, AZ
Looks like you can still order it via Mopar east through this link - https://www.eastcoastmoparts.com/oem-parts/mopar-jumper-wiring-68347117ab
