Installing wheel spacers solo
Ron-Short
Ron
St George, UT
2024 Rubicon 392
I’m gonna be installing my wheel spacers soon and will be doing it alone.
My question is this is when i torque down the wheel spacers the brakes need to be applied. My thinking is if I put it in four-wheel-drive and turn on the lockers, then jacking up one wheel at a time I should be able to torque them adequately without having someone hold the brakes
Does this make sense or am I just being dumb?
jadmt
jeff
montana
I just use a stick to push on the brake pedal. Wedge it between the brake pedal and seat bracket
dchemphill1
Nebraska
2020 Wrangler Rubicon Recon
School Administrator
I believe if you put it in 4lo before jacking up and working on tire it should not spin on you.
Terrymo
Terry
2023 JLURXR 3.6 ET
My question is this is when Twerking down the wheel spacers the brakes need to be applied.
I suggest not Twerking and working on your Jeep at the same time. Stay focused.
