MyDaughters20JL
More than likely, it's simply the fact that my previous vehicle was a 1 ton supercrew powerstroke 4x4, but I"m a little bit bummed regarding the ride of my '20 JLUR as far as stiffness of the ride. Yes, I'd like a little softer than my ford, but for god sakes, is it too much to ask for something a bit more firm?
current setup & mods are as follows:
Rough Country 2.5" spacer lift
teraflex shocks
Core4X4 adjustable front track bar
Synergy rear track bar relocation bracket
Synergy rear track bar frame brace
Raceline wheels with +35 offset
35" (315) BFG KO2's
I notices that SOME of the lift kits that are out actually raise the front end a bit more, I assume this is to remove the factory rake.
with a straight 2.5" spacer lift, I still have the rake & I have yet to install my ARB twin compressor (in engine compartment) OR my Badlands apex 12K winch.
I did go with aftermarket bumpers, but figure that with front (westin wj2 full width) and rear (body armor full width) the weights somewhat equalled each other & wouldn't change the rake for the most part...
considering I"ve yet to install the winch, would an investment in a heavier set of springs for the front (thinking diesel 4 door with hard top and towing package) remove most of the rake and stiffen things up a bit once I get my wi9nch on (I already purchased the Core4X4 adjustable front LCA's simply because, although not nearly as bad as BEFORE the steering box replacement, there is a bit more looseness in the steering "post lift", and that's WITH the longer MOPAR LCA's)?
all thoughts are welcome, even if you think I"ve overdone some things & underdone others
teraflex shocks
35" (315) BFG KO2's
