Hydralic trolley jack
Sanchese
Carlos
Toronto, Canada
2021Rubicon, 2022 Rubicon Xtreme Recon on Order
I am looking for a hydralic trolley jack that would work without me having to add a wood block to get enough height so I could change my tires.
Thanks
db_racer
Toronto
2020 Jeep JL Saraha
Thanks
See your from Toronto. This guy from Canadian Tire is solid. Can lift 24" @ full extension whereas most other trolley jacks do 17 to 19" on avg.
https://www.canadiantire.ca/en/pdp/...le-long-reach-garage-jack-3-ton-0090244p.html
I own one and can confirm it can lift a 2020 jlu sahara off the ground no issues from the side frame with capacity to spare. My older trolley jack (unknown spec) couldn't even lift it off the ground at full extension whereas it worked fine for regular passenger cars.
limeade
Guy
Reno, NV
If you're lifting the jeep from the frame to change a tire, you're doing it wrong. Just put the jack pad under the axle somewhere to lift the axle so you don't have to worry about axle droop. For the rear axle, put the jack under the differential, lifts both sides about equally. Get a set of jack stands to support the axle.
