geekyrocketguy
- May 19, 2016
- CA
- Website
- www.sgphotos.com
- 2022 Rubicon Unlimited
Hi All,
I removed the driver-side rear seat from my 2022 JLUR. When I put it back in, I mis-read a torque spec and broke a bolt on the bracket that holds the seat to the vehicle floor. So I bought a new bracket, which is part 68281222AD (#11 here). I went to replace the broken bracket with the new one, and this involves removing the bracket from the passenger-side rear seat. The seat unzips to reveal two bolts (see the photo below). These bolts thread into nuts inside a rectangular tube (see the second photo). The nuts are not held in place; they spin when I try to remove the bolts. The only access hole is through the end of the tube. Clearance is extremely tight and access is poor. I can hardly see what I'm doing.
Does anyone have information on how to hold these nuts in place while removing the bolts? What size are they? The bolt has a 15mm head. I've tried 15, 16, and 17mm wrenches and couldn't get a good grip. My 18mm wrench doesn't fit into the tube.The nut has 8 sides, so it's not a standard 6-side nut.
This is the worst part access I've ever seen.
Thanks in advance for the help.
