How far will wheels stick out
bharvey88
Brandon
Oceana, WV
2019 Jeep Wrangler Unlimited Sport S
New to Jeeps…I have a stock sport s and I’m going to a 17x9 with 5 inch backspacing and 0 offset. The backspacing/offset thing is always confusing for me so if someone can help give a pretty straight forward answer I’d appreciate it.
jhackathorne
Denver
'21 JLUR
Should be right around the fenders for the edge of the tires. Maybe sticking out ever so slightly. I’m running +20 on the wider Rubicon axles and have about 1” poking out.
Hucke_250
Ohio
2018 Unlimited Sport
What size tire are you planning on running? I have 20x9 +1 offset (5.040 backspace) with 35x12.5x20 tires and they stick out 2.5 inches from the Sahara/sport fenders.
blnewt
New Mexico
Just ask @cosine he knows!
Here's my fender fit when stock (245/75/17 on 7.5 +44) and 295/70/17 on 17x8.5 +10
Jeep Wrangler JL How far will wheels stick out 100_4025
bharvey88
Brandon
Oceana, WV
Perfect. Thank you guys for the help
someone asked what size tire I’m running and it’ll be a 265/70/17 simply because I put on a pretty good amount of miles for work and want to get a little more aggressive while also preserving as much MPG as possible. I know I could go up to a 33 but for the moment I plan to stick to the 32s
Hucke_250
Ohio
After using a tire size comparison calculator it looks like the 265/70/17 your planning to use is 2 inches narrower than the 35x12.5.20 I am running. So I would expect that your 265/70/17 on a 17x9 +0 wheel will stick out a 1/2 inch from the fender.
Rangemaster
Nevada
2020 JL Rubicon Diesel
Business Owner
What size tires will you be running? Larger tires may rub inner fenders and linkage.
Nevermind, someone bet me to this. Got busy while typing.
Rayoung
Rob
Ohio
Hey, I was wondering if you ended up getting those wheels and tires. If you did, are you able to share some pictures? I’m in a similar situation and curious to see how they stick out before I make a decision. Thanks!
bharvey88
Brandon
Oceana, WV
I actually haven’t. The wheels have been put on back order and aren’t expected to ship out until the end of September sometime. I got a good deal on tires locally though so I actually put 285/70r17s on though
