https://tiresize.com/wheel-offset-calculator/Anyone have pictures they will share?
Looking at XD rims.
Thanks!
Thanks for the pic. From the front they look good.best front end shots i got of my 37x12.5
Thanks for the pics! Have you noticed any issues with drivability? That was my other main concern with increasing the track width that amount.315 70r17 KO2 +1 offset. Used a straightedge against sidewall the widest is 2 1/4* out of the fender. The actual tread is 1 1/4" outside the fender. I love the look personally, but thats Me.
I'm 4" over stock height and have 17x9 wheels with -12mm offset and 38x13.5's. The wider track definitely gives more side to side stability on curvy roads and cornering. Also, more stability with off camber situations.Thanks for the pics! Have you noticed any issues with drivability? That was my other main concern with increasing the track width that amount.
i think the stance is perfect with the larger tires. Not sure how it will look with the 35's i have purchased.I'm 4" over stock height and have 17x9 wheels with -12mm offset and 38x13.5's. The wider track definitely gives more side to side stability on curvy roads and cornering. Also, more stability with off camber situations.
I've definitely seen your setup on both stock height and lifted Rubi's, and it looks sharp. I've also seen stock tires with the same offset, but it looks strange with the narrower factory tires.i think the stance is perfect with the larger tires. Not sure how it will look with the 35's i have purchased.
Man I sure hope so. Wheel and tire selection has been the toughest thing I have had to decide in a whileI've definitely seen your setup on both stock height and lifted Rubi's, and it looks sharp. I've also seen stock tires with the same offset, but it looks strange with the narrower factory tires.
